1. AC Question's Avatar
    Every time I power on my phone it has a notification about there being an SD card in it, I know I can simply swipe it off the screen and it never comes back (until the next reboot), but where's the option to turn this notification off for good?
    There's always an SD card in my phone, I know this, so I should be able to turn off the notification altogether.
    04-15-2016 10:31 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Is this the S7? If so, I think that is baked into Samsung's version of the OS.
    http://forums.androidcentral.com/sam...ml#post5054592
    04-15-2016 10:42 AM
  3. dpham00's Avatar
    Although I wouldn't advise it, you can disable this message by using package disabler and disabling the "system ui" package.
    04-15-2016 10:45 AM
  1. How do you move pictures from internal storage to card?
    Last Post: 04-20-2016, 10:07 PM
  2. Replies: 2
    Last Post: 04-19-2016, 08:19 PM
  3. Why won't my number go off on unread message notifications?
    Last Post: 04-18-2016, 02:49 AM
  4. Use Different Notification Sounds for Apps
    By bryancorbin in forum LG G3
    Last Post: 04-15-2016, 11:13 AM
