when I text someone my keyboard stopped appearing now a microphone pops up wanting me to talk so it can spell it out. I never ``turned this feature on and want my keyboard back
Printable View
Are you sure you didn't install an app that has this among its features/abilities? Or perhaps your device took on some Android updates that contain this new ability. Try digging deep into the Settings section for Accessibility or special features, there might be a switch for this feature that got turned in somehow.
I'm having a not-too-different issue myself; every time I turn my phone on, the WiFi antenna self-activates. Thus started happening a few days ago (I've posted it as a thread). If I don't get any replies, I'll try Yahoo Answers or some other place.
By the way, what device with what Android version are you using?
With most keyboards it's on the bottom of the screen (a little keyboard), the same key you (usually long-press) to get the mic with or of it's Google just hit the back key to get it off.
