1. xenadream's Avatar
    all my notes are visible but when I try to open them, it says note broke. a few days ago, I unsynced some programs. could I have closed the wrong one down? thanks
    04-16-2016 05:29 PM
  2. srkmagnus's Avatar
    Try clearing the cache of the Scribble App and see if that helps. Do you know what programs you closed? I don't think any of those could have created this issue.
    04-16-2016 07:11 PM
  1. I want to Debrand my Samsung Galaxy S6 Edge + SM-G928A
    By thelittleleto in forum Samsung Galaxy S6 edge+
    Last Post: 10-04-2016, 01:45 PM
  2. How do you download operation system
    Last Post: 04-17-2016, 02:11 AM
  3. How do you use Samsung smart multimedia hub with s5?
    By xbnew in forum Samsung Galaxy S5
    Last Post: 04-16-2016, 08:11 PM
  4. I need my pin to my Google acct
    Last Post: 04-16-2016, 06:09 PM
  5. How and where do I mount an SD card for Samsung Galaxy Tab 4
    Last Post: 04-16-2016, 05:01 PM
