Hi,
I own a Honor 5x no-brand.
First thing I did with the phone was unlock the bootloader, install TWRP and root it.
Yesterday morning the phone notified me about an available upgrade to EMUI 4.0, which I did with the updater of the phone itself. According to the phone the update was successful. When the phone rebooted itself, it got stuck at "honor" in white with black background. and won't continue booting.
I tried the following solutions:
Put the telephone in Fastboot & Rescue Mode and connect it to HiSuite (the phone says "Phone unlocked" and "FRP Unlock"). HiSuite does not recognize the phone, even though Windows installs the drivers. In HiSuite he only available option was System Recovery wich started but then it immediately said the phone is not supported.
I downloaded 2 different firmwares e copied Update.app to a folder called dload in the SD root. I pressed both volume buttons and the power button. The installation started but then returned the error "Installation Failed" in both cases. I did this with the USB cable disconnected as I read it won't work if it is connected.
In the Huawei eRecovery menu (which I accidentally discovered playing around with the volume buttons and the power button) I tried an update through WiFi. It apparently connected to WiFi (I tried 2 wich I connected the phone to when it was working) but then it said it couldn't connect to the server.
In the same menu I tried cleaning the cache (which it seems it worked) and to wipe everything and restore to factory settings. Actually it started formatting, until 15%, then jumped to 100% and showed a message during a fraction of a second that I believe said "100%" and "Success" (it disappeared too fast to be sure). When I rebooted the phone nothing was solved.
ADB does not recognize the phone, Even though I could reinstall TWRP I couldn't reboot to recovery as the phone is not recognized. I reinstalled ADB but no luck.
Power button + volume up does not take to TWRP.
Please, any help will be greatly appreciated.
TIA
TIA
