Hello guys,
Weird question that I just can't seem to find (easily) out there. I know you can block notifications for each app in Android by toggling the appropriate switch. BUT what I'd like to know is how this 'block' works. Here are the two ways I think it could be working, but I'd like to know which one is the actual way it does it (or if I'm way off on how it is).
1) Apps with blocked notifications will not receive notifications at all in the background (thus, no data used) and therefore, no notifications will be displayed in the system. This would be the ideal case, me thinks.
2) Apps with blocked notifications are still receiving them in the background (data used), but the system simply chooses to ignore them and doesn't display them as notifications. This would be less ideal since you're still using data and the app is still doing things in the background.
Why do I ask this? Apps that have non-synced notifications. I just loooove checking notifications from Facebook, Messenger, Instagram, and Twitter all day in my phone only to come home and be bombarded with the same ton of notifications I already dismissed. I'm not sure why Messenger sometimes does sync them, sometimes (most of the time) it doesn't. So, I'd like to restrict notifications for those apps and save a little battery in the process, but I'd like to know if I would actually be saving in battery because they won't be using data and not receiving anything in the background or I won't be getting any benefits because the system just isn't displaying them.
