1. opallo's Avatar
    Hi,
    I'm wondering if someone had the same problem. I'm using Asus Zenfone 2 Laser, android 5.0.2.
    After charging, the battery drains quickly and there's much more RAM used than normally. After restarting the device everything works fine and the battery lasts at least for two days. This happens every time I charge the device.
    I don't need to tell that restarting phone after every charging is pretty annoying
    Thanks for every answers.
    04-27-2016 03:21 AM
  2. belodion's Avatar
    If you let it drain for a bit before rebooting, what do your battery usage stats indicate as the cause?
    04-27-2016 06:10 AM
  3. opallo's Avatar
    I've got the same apps that after charging (zenui launcher, mail, chrome, splendid, clock and google services).
    Maybe there's some memory leak? that would explain why the issue is gone after rebooting.
    04-27-2016 06:15 AM
  1. Battery & Cradle sale $20
    By corvette72778 in forum LG V10
    Last Post: 05-07-2016, 02:04 PM
  2. Does AT&T LG G3 support wireless charging?
    Last Post: 05-06-2016, 04:55 AM
  3. Pocketnow HTC 10 camera review after update.
    By Rizwan Basir in forum HTC 10
    Last Post: 05-04-2016, 02:22 PM
  4. How can I stop my phone from heating up and not charging?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-27-2016, 05:54 AM
  5. Replies: 0
    Last Post: 04-27-2016, 02:54 AM
