1. Ulises Rios's Avatar
    The thing is that yesterday I restarted my cellphone because the apps were stopping, so when I turned it on again the signal bar is showing a red cross and also the data is blocked, there's no way to turn it on I made a factory reset and a hard reset and still not working. What should I do? I have an LG L70
    04-29-2016 07:00 PM
  2. ratsttam's Avatar
    Sounds like a defective sim card, or worse, defective sim card slot.
    If your carrier has a local store, you can probably take it there and ask for a new sim card (they can and do go bad), and see if that helps.
    04-29-2016 09:05 PM
  1. Replies: 1
    Last Post: 05-02-2016, 11:30 PM
  2. I can't turn on data and also I don't have mobile network
    Last Post: 05-02-2016, 11:28 PM
  3. Can I transfer a CWM backup to another phone?
    By jcase469 in forum Sprint Galaxy Note 2
    Last Post: 04-29-2016, 09:51 PM
  4. Replies: 0
    Last Post: 04-29-2016, 06:53 PM
  5. Can i add qi wireless charging to my lg g sytlo ls770
    By alichamw in forum More LG Phones
    Last Post: 04-29-2016, 06:01 PM
