Panasonic Eluga I Restarting. How can I stop this?
A
AC Question
Panasonic Eluga I Restarting itself after sometime and unnecessary apps are also installing .these are happened after mobile fallen down and screen broken........after changing display and software also it is restarting and apps are installing....Can u help me in this problem
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,660
113
Welcome to Android Central! What apps are installing on their own? Chances are that you installed some adware or malware unwittiingly in the past that is doing this. Have you already done a factory reset?
Markizta
