1. AC Question's Avatar
    I recently received a Shield K1 as an anniversary gift from my wife. I would like to expand its storage with a memory card (SanDisk Extreme Plus 32 gb) but I have fears that this will negatively impact performance. If it does slow the tablet down more than I am comfortable with, will the table work if I remove it? What if the card wears out due to repeated use? Will this end the tablets effective life? Would the tablet still work, but only with a factory reset?
    05-03-2016 03:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! According to Motorola's FAQ, "If you remove an adopted card from a device, the system will request the card be reinserted; you will lose access to apps and data on the card until it is safely re-inserted." Since Adoptable Storage is a Marshmallow feature, and not device-specific, this should apply to the Shield as well.
    I'm not sure if it's possible to reverse the adoptable storage decision, although I would guess that a factory reset could do it.
    05-03-2016 11:41 PM
  1. Replies: 3
    Last Post: 07-13-2016, 08:09 AM
  2. Replies: 2
    Last Post: 05-14-2016, 12:43 PM
  3. Do you know how to remove an S6 Edge dot pixel?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 05-03-2016, 11:47 PM
  4. USB not working with PC!! Why?
    By allanbasil in forum Xiaomi Android Phones
    Last Post: 05-03-2016, 03:38 PM
