1. AC Question's Avatar
    My tecno p5 can't open its just displaying tecno
    05-05-2016 09:55 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Why did you do a factory reset? Was it acting up beforehand?
    This kind of issue usually represents a firmware or hardware problem, and can be difficult to solve. The only thing I can suggest is remove the SD card (if present) and try rebooting again.
  3. B. Diddy's Avatar
    05-05-2016 12:27 PM
  1. Replies: 2
    Last Post: 05-13-2016, 12:06 PM
  2. How long should the battery on S3 last?
    By charlesxy in forum Batteries
    Last Post: 05-13-2016, 12:03 PM
  3. Replies: 1
    Last Post: 05-05-2016, 12:33 PM
  4. Can I do ANYTHING to get my Nexus 7 2013 working again
    Last Post: 05-05-2016, 09:47 AM
  5. Notification vibration pattern changed, how do I change it back?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-05-2016, 09:43 AM
