1. AC Question's Avatar
    i have infocus m2 3g mobile..it often gets switched off when the charger is removed.It also insists a warning that temperature is high so the is going to get shutdown..this happens when the charger is removed..pls give me asuggestion
    05-05-2016 11:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is the temperature not really high, even though the phone says it is? If so, I would suspect some hardware defect. This kind of thing tends to occur after water damage--any recent exposure? In any case, you'd probably have to bring it to a repair shop (or contact the manufacturer, if it's under warranty).
    05-05-2016 01:25 PM
  1. What is a Recommended Portable Charger/Battery for the S3?
    By charlesxy in forum Samsung Galaxy S III Accessories
    Last Post: 06-14-2016, 05:26 PM
  2. How long should the battery on S3 last?
    By charlesxy in forum Hardware Hideaway
    Last Post: 05-13-2016, 01:03 PM
  3. Replies: 1
    Last Post: 05-05-2016, 01:33 PM
  4. My Tecno won't start after I have done a hand reset, what should I do?
    Last Post: 05-05-2016, 01:27 PM
  5. Why is my phone saying "Samsung Accessory Service has stopped"?
    Last Post: 05-05-2016, 01:26 PM
