1. mezomezo's Avatar
    i have galaxy note 2 , rooted , with resurrection remix ( android 6)
    i am stuck on boot screen , i tried to reinstall and factory reset , install a newer version but no sucsess
    what should i do
    05-06-2016 04:34 AM
  2. srkmagnus's Avatar
    what should i do
    Restore the backup you made before trying to flash the ROM. That will get you back into the system until you can figure out why it's not booting. Follow the flash instructions provided by the developer and see if that fixes your problem.
    05-06-2016 10:11 AM
  3. mezomezo's Avatar
    i dont have a backup . so what can i do in this case , and thank you
    05-06-2016 11:24 AM
  1. How do i stop split screen on my samsung galaxy s6 edge?
    By Kelsey Ward in forum General Help and How To
    Last Post: 05-06-2016, 11:14 AM
  2. Dr Beats headphones issues, keeps on dropping
    Last Post: 05-06-2016, 07:19 AM
  3. Lost home page on Samsung galaxy s6
    Last Post: 05-06-2016, 04:24 AM
  4. Replies: 0
    Last Post: 05-06-2016, 02:27 AM
  5. Replies: 0
    Last Post: 05-06-2016, 02:18 AM
