My calendar settings self-adjusted one hour this morning with the automatic daylight savings time change. Every calendar advanced one hour. Anyone at sprint have a suggestion for a user with a $276 a month billing account?
Probably another, related, bug as seen on my Opitmus V: DST did not take effect on the displayed time until I switched back to 12-hour mode from my preferred 24-hour mode (even with a power recycle). Then it was correct, and also when I switched it back to 24-hour display mode.
Not sure which action did the trick, but after reading and being frustrated this is the sequence:
1)set clock to 24 hour
2)unmount SD card
3)power down phone
4)wait 10 seconds
5)power up phone (SD card remounted automatically)
Time reset correctly automatically!
6)reset clock to 12 hour (my preference)
