Hey guys, hoping for some help here.
I have a Samsung Galaxy tab s2 and I bought a 128GB micro SD card for it. I put the card in and the device seems to be recognizing it. When I try to move apps over to the card, it says they've moved when they have not. The device storage remains exactly the same, as does the card storage (120gb free).
I know that not all apps can be moved to the SD card, and I know that sometimes only a small portion of a particular app can be moved. But literally nothing is moving. I also have a Samsung Galaxy s3 phone, and I have moved these same apps to the SD card with no problem.
