1. brentendo64's Avatar
    Hello, ever since upgrading to Marshmellow, a lot of my phone settings have gone whack. The most annoying one is that whenever I make a call, the call screen jumps up to the notification bar. The main screen either goes black or stays on the new call keypad screen.
    If I want to do things such as hangup, enable speaker, or use the keypad, I have to swipe down from the top and find my call first. If I bring the phone down from my ear, the screen flashes on for about half a second before going back to black, making it more frustrating as I have to hit the lock button to bring the display back.
    How can I prevent my current call from immediately jumping up to the notification bar? I've already tried adjusting Phone settings. My phone is an s5, thanks!
    05-15-2016 11:19 AM
  2. VidJunky's Avatar
    Is it possible that your light sensor is dirty? That may explain some of it. Also are you using any third party apps for; dialer, launcher, or other calling, like internet calling, anything like that?
    brentendo64 likes this.
    05-15-2016 11:27 AM
  3. brentendo64's Avatar
    I am making regular voice calls. Tried uninstalling phone recorder and setting touchwiz as the default launcher (was Google Now). Problem still happening though. I am using the stock dialer. I might try a third party dialer if I can't find the fix though.
    05-15-2016 11:49 AM
  4. brentendo64's Avatar
    Phone app started working correctly after setting default launcher to Touchwiz AND restarting. Thanks for the help!
    05-15-2016 12:02 PM
  1. How to remove background in display panel
    Last Post: 05-21-2016, 11:51 AM
  2. Replies: 5
    Last Post: 05-15-2016, 02:19 PM
  3. Replies: 3
    Last Post: 05-15-2016, 12:42 PM
  4. How I can Update HTC Desire 820 S to Marshmallow??
    Last Post: 05-15-2016, 11:28 AM
  5. Why it appear no sim card emergency calls only
    Last Post: 05-15-2016, 09:43 AM
