1. AC Question's Avatar
    I will donwload an file from the internet and as soon as i go of the internet the download will dissappear but if I pull the notification bar down as soon it starts to download it will carry on but if go off it the download will dissappear.
    05-24-2016 03:38 PM
  2. SpookDroid's Avatar
    That's because the notification you're seeing is a download progress indicator. When you go offline, the file is just not downloading anymore, so the file is either truncated/cancelled or just deemed finished.
    05-24-2016 04:52 PM
  3. 359 Degrees's Avatar
    Are you using the stock browser or another browser app? Because I know with Dolphin, if you leave the browser, the download stops and it doesn't pop up in your notification bar. Could be the same thing for your browser.
    05-24-2016 04:53 PM
  4. thed4n786's Avatar
    No i am usin the default internet browser and my wifi will still be on but it will cancel the download as soon as i leave the internet application
    05-27-2016 03:26 PM
  5. SpookDroid's Avatar
    can you try a different browser? Not sure which phone you have so don't know what your 'stock' browser is. But I think Chrome doesn't do this.
    05-31-2016 11:43 AM
  6. thed4n786's Avatar
    I have a samsung s6 but it just does not download i tried using es downloader ot will work while i am on the app but as soon as i leave it the download fails
    06-01-2016 12:17 PM
  7. SpookDroid's Avatar
    Check if any of the apps have background data restricted
    06-01-2016 01:21 PM
  8. markjoseph talactac's Avatar
    Youre using power saving mode . Turn it off and ur good to go
    12-29-2016 02:31 AM
  1. Why won't my ZTE turn on?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 05-24-2016, 06:23 PM
  2. Replies: 2
    Last Post: 05-24-2016, 05:57 PM
  3. NEED HELP - I think I bricked my s7 edge
    By rkuyy in forum Samsung Galaxy S7 edge
    Last Post: 05-24-2016, 04:59 PM
  4. phone power button broken--how to turn on?
    By alistarrr in forum Sony Xperia Z2
    Last Post: 05-24-2016, 03:05 PM
  5. How can I tell what my phone is downloading?
    Last Post: 05-24-2016, 02:48 PM
