1. Taran Middleton's Avatar
    Title. I haven't done anything to turn the animation off, so I have no idea why it's turned off . Not that important, but it's really disconcerting when in used to the animation.
    05-26-2016 05:32 PM
  2. H3aTeRzz's Avatar
    Hi there Taran!
    So screen rotation is turned off? When you turn phone sideways, it doesn't rotate?
    Pull down your notification window and re-enable it from there. If you're referring to something else, then I would suggest to enter recover and wipe the cache partition, see if that helps.
    Chris
    05-26-2016 06:34 PM
  1. Can't delete my google account
    Last Post: 06-02-2016, 09:39 AM
  2. Replies: 5
    Last Post: 05-29-2016, 07:40 AM
  3. Can't delete my google account
    Last Post: 05-26-2016, 06:30 PM
  4. Replies: 1
    Last Post: 05-26-2016, 06:29 PM
  5. Replies: 1
    Last Post: 05-26-2016, 05:18 PM
