1. kramer5150's Avatar
    Heres a new one... Every once in a while I get this triangle logo at the top of my screen next to the WiFi symbol. Its only there for a few seconds and then disappears.
    What does it mean? Is it mal-ware related or have anything to do with my weak cellular signal?
    thanks!!
    05-28-2016 04:21 PM
  2. Aquila's Avatar
    Looks like you're on a G5. Is that right? Triangles usually are either "system error" or "sync failure", but it's hard to tell without any additional info.
    05-28-2016 07:34 PM
  3. kramer5150's Avatar
    Its an LG V10.
    05-28-2016 08:55 PM
  4. flintlock's Avatar
    Check settings, about phone, icon glossary.
    Aquila likes this.
    05-28-2016 09:02 PM
  5. cirkit's Avatar
    I do believe that is the symbol for Roaming.
    You should check your data settings that might help you out.
    Aquila likes this.
    05-28-2016 09:05 PM
  6. kramer5150's Avatar
    OK thanks!!
    05-28-2016 09:49 PM
  7. Laura Knotek's Avatar
    Looks like roaming.
    Phone’s Status Icons
    Aquila and Sam_Gs7 like this.
    05-28-2016 09:53 PM
  8. kramer5150's Avatar
    Looks like roaming.
    awesome! thanks everyone!!
    Laura Knotek and Aquila like this.
    05-28-2016 10:07 PM
  9. Danish Mat's Avatar
    This icon indicates that your data saver option is enabled.
    04-07-2018 09:30 AM
  10. huntersue's Avatar
    Triangle with up & down arrows in center indicates your Data Saver is enabled
    09-10-2019 06:18 PM
  1. What is the best version of the android ?
    Last Post: 05-28-2016, 07:17 PM
  2. What is the mysterious app simply named gamestore?
    Last Post: 05-28-2016, 06:39 PM
  3. what does the magent do with a Google cardboard headset?
    Last Post: 05-28-2016, 06:33 PM
  4. What is 10556,in the battery usage
    Last Post: 05-28-2016, 05:13 PM
  5. Replies: 1
    Last Post: 05-28-2016, 09:26 AM
