1. DocDouglas's Avatar
    I just updated my Galaxy S5 (stock, unrooted) device to MM throught OTA. I've had a few bugs (No SIM icon missing, and hitting back to cancel highlight on Chrome causing app to close) which persisted after factory reset, so I considerated the option of using Kies to reflash the custom ROM to the phone...
    Is Kies able to be used in that way? Will the ROM be a clean install or it's about the same to a default factory reset? Are there any risks in the process?
    05-30-2016 05:20 PM
  2. srkmagnus's Avatar
    Unfortunately guys will not allow you to restore or refresh the factory image. For that you would need to use a separate program called Odin and the appropriate factory image.
    05-31-2016 02:17 PM
  3. DocDouglas's Avatar
    I thought it really might just install over the old one...
    Thanks a lot mate, saved me some time there... Haha
    BTW, do you think reflashing (the same official 6.0.1 MM ROM) might do any good or I'm (WE really, since there's a lot of people in the same boat) probably facing build specific issues and should wait for a new patch?
    05-31-2016 02:28 PM
  1. Why do apps want access to "all" the information on my S3?
    Last Post: 05-30-2016, 08:22 PM
  2. What is eyeballsdk I keep seeing I'm my phone
    Last Post: 05-30-2016, 04:13 PM
  3. Replies: 0
    Last Post: 05-30-2016, 04:08 PM
  4. Replies: 0
    Last Post: 05-30-2016, 04:03 PM
  5. How do I zip large video file to email
    Last Post: 05-30-2016, 03:25 PM
