1. AC Question's Avatar
    My keeps freezing up an it stops all the time battery gets hot an sometimes says that a certain app isn't responding what can I do to fix this
    06-03-2016 08:07 AM
  2. the tall guy's Avatar
    Hi, try booting your device into safe mode - if the phone works as it should then the problem lies with one of your 3rd party apps that you have downloaded.
  3. the tall guy's Avatar
    06-03-2016 08:36 AM
  1. Android device manager won't accept my Google password, why?
    Last Post: 06-04-2016, 02:20 AM
  2. Replies: 1
    Last Post: 06-04-2016, 02:18 AM
  3. Replies: 0
    Last Post: 06-03-2016, 06:32 AM
  4. My unit is Myphone Agua Rio. How to fix it?
    By Demi Ann in forum Ask a Question
    Last Post: 06-03-2016, 06:29 AM
  5. Replies: 0
    Last Post: 06-03-2016, 06:26 AM
