1. AC Question's Avatar
    I have an Alcatel one touch pop astro. I have close the 100 mb left. I have a 1.5 GB phone. It does load my launcher often. Even with launcher apps. Some help?
    06-03-2016 09:10 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sorry, but I'm not exactly sure what the problem is. What do you mean by "loading the launcher often"? The Home button is supposed to activate the launcher, because the launcher brings up your homescreen.
    Are you saying that even when you have an alternate launcher (like Nova) installed and working, the stock launcher shows up as open in RAM? If that's the case, then go to Settings>Apps>All, and disable the stock launcher app (while you're using an alternate launcher).
    06-04-2016 01:08 AM
  1. Replies: 2
    Last Post: 07-21-2016, 05:37 PM
  2. Why is the IR light on continuously, on my LG Flex2?
    By AC Question in forum LG G Flex 2
    Last Post: 06-04-2016, 05:31 AM
  3. Replies: 2
    Last Post: 06-03-2016, 10:24 AM
  4. Can I rid of the LGV10 smileys?
    By AC Question in forum LG V10
    Last Post: 06-03-2016, 08:49 AM
  5. Please help my LG is stuck on the LG screen, how do I unfreeze it?
    Last Post: 06-03-2016, 08:29 AM
