1. Odney Telusma's Avatar
    I have a Samsung galaxy exhibit that has no service, the sim card was deactivated when I got my new phone. What I need help with is my wifi calling, ever since the deactivation, it has stopped working even when I set wifi calling to wifi only, I would assume it is specific problem with the provider witch was Metro PCS because people on the web have said that wifi calling will still work on a deactivated phone. Would removing the sim card allow wifi calling to work?
    06-04-2016 02:32 PM
  2. B. Diddy's Avatar
    You still need the phone activated on the carrier's network if you want to use the carrier's own wi-fi calling service. For a phone that isn't activated on a carrier, you can use Hangouts Dialer or Skype to make VOIP calls.
    06-04-2016 03:50 PM
  1. my kyocera hydro view phone is stuck on the shut down screen
    Last Post: 01-25-2017, 01:48 AM
  2. Imo denied to use camera on my canvas 6 pro
    By Android449 in forum Ask a Question
    Last Post: 12-01-2016, 01:37 PM
  3. Replies: 1
    Last Post: 06-04-2016, 07:37 PM
  4. Replies: 1
    Last Post: 06-04-2016, 04:37 PM
  5. Contact image not showing when receiving incoming phone calls.
    By pascaldemo in forum Samsung Galaxy Note 4
    Last Post: 06-04-2016, 01:21 PM
