1. AC Question's Avatar
    Everything I try to select creates a thick blue box around it and I have to hit it twice in order to open the app. Also, it will not allow me to scroll any screens left to right or up and down? Help!!
    06-06-2016 08:29 AM
  2. belodion's Avatar
    What is the app?
    Laura Knotek likes this.
    06-06-2016 08:55 AM
  3. Morty2264's Avatar
    Can you take a screenshot of that icon to show us, please?
    06-06-2016 10:53 PM
  4. Chocapoky5's Avatar
    I just had this happened to me and I had absolutely no idea what was wrong with my Galaxy Note 5. I am suspecting it to be a virus of some sort. I had to force through the apps (by pressing hard and then double tap on my selection) to get into reset factory setting and then everything was ok. I had GO SPEED app downloaded on my phone which I started using today. I am suspecting its that app so I uninstalled it immediately.
    Any other suggestions?
    06-09-2016 06:31 AM
  5. belodion's Avatar
    Welcome.
    Did you Clear Cache, Clear Data, Force Stop, then Uninstall?
    If you still have the problem, try Safe Mode to test whether a third-party app is causing trouble.
    06-09-2016 06:42 AM
  6. Javier P's Avatar
    It sounds like TalkBack is enabled in your accessibility settings. To go there and disable it you need to double tap to select the different options and swipe with two fingers to navigate through the menus. Tell us how it goes.
    06-09-2016 07:39 AM
  1. Samsung S5 - Power saving icon top left, how do I get rid of it?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 07-03-2016, 01:01 PM
  2. Facing auto touch problem in moto g3
    By Sunil poojary in forum Moto G
    Last Post: 06-10-2016, 01:30 PM
  3. Why isn't YOUTUBE not playing on my HTC One M8?
    By AC Question in forum HTC One M8
    Last Post: 06-09-2016, 08:59 AM
  4. Replies: 1
    Last Post: 06-07-2016, 08:43 PM
  5. Why does my S5 mini drop from wi-fi connections so frequently?
    By AC Question in forum Samsung Galaxy S5 Mini
    Last Post: 06-06-2016, 07:53 AM
