1. AC Question's Avatar
    i was rebooting my gionee p4 in between i remove the battery after that it is not turnig on pls help me its very urgent.....
    06-07-2016 05:12 AM
  2. belodion's Avatar
    Remove the battery and press Power for ten seconds. Then replace the battery, and press and hold Power until the phone boots.
    If no go, get back to us.
    06-07-2016 06:06 AM
  1. Replies: 3
    Last Post: 01-22-2017, 11:09 AM
  2. Why does the Figure 8 gesture for the compass not work?
    Last Post: 06-07-2016, 06:58 AM
  3. What cell phone will support the a 256 GB micro SD card?
    Last Post: 06-07-2016, 06:57 AM
  4. I have the same problem too.
    Last Post: 06-07-2016, 04:39 AM
  5. Replies: 0
    Last Post: 06-07-2016, 04:24 AM
