Is it possible to disable Android notifications?
  • Start date Start date
A
AC Question
Is it possible to disable android notifications?
I'm just wondering if it's possible to disable the default notification in favor of the notifications app i use (floatify) right now i see my notification but in the background i can also see the default system notification as well, if i disable them per app notifications all together disappear.
Re: Is it possible to disable android notifications?
Look in the system settings under Security / apps with access to notifications or something similar.
pupso4ev
