1. Uma Datt Upadhyay's Avatar
    Hello friends,
    I am uma datt upadhyay , and i want to block my laptop USB port, because some person and people are every time use my laptop and connect different different pendrive, thats why i want to do this, and i dont know, how to i do.
    please help me,
    06-10-2016 07:29 AM
  2. myportablesoftware's Avatar
    You can disable the USB ports using the Device Manager.
    There is also an utility which can do this for you (just search it with Google).
    You can also disable them in BIOS. This last option is the best because you can protect BIOS access with a password.
    06-10-2016 07:57 AM
  3. Uma Datt Upadhyay's Avatar
    Thank you .
    06-10-2016 08:49 AM
  1. How do I change my Droid Turbo 2 photo saving destination to the SD card?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 06-11-2016, 11:19 AM
  2. How can I flash an LG G Stylo?
    By Mikew64 in forum Legacy Android & Other OS's
    Last Post: 06-10-2016, 03:37 PM
  3. Replies: 1
    Last Post: 06-10-2016, 08:06 AM
  4. How can I fix the music preview on my Google Play Music?
    By AC Question in forum Google Play Store
    Last Post: 06-10-2016, 07:48 AM
  5. Why can't I update my GS4 I9500 beyond 4.2.2?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 06-10-2016, 06:07 AM
