1. AC Question's Avatar
    there is only a blank green screen nothing to select or click on
    06-20-2016 07:15 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It can be difficult to troubleshoot these direct-from-China Android TV boxes, since support is minimal and quality control is probably suboptimal. I would normally suggest contacting the manufacturer, but I can't find a website for them. You could try posting over at FreakTab, which has a more robust Android TV box discussion: freaktab.com/forum/tv-player-support
    06-20-2016 02:10 PM
  1. blu Life xl no lte on at&t
    By rich250 in forum Blu Android Phones
    Last Post: 07-12-2016, 08:58 PM
  2. "getting massage MediaServer failed. Restart Camera.
    Last Post: 06-20-2016, 08:38 AM
  3. How to install the app superuser on my Motorola Droid Turbo
    Last Post: 06-20-2016, 08:35 AM
  4. Why aren't the sounds on my S7 Edge working?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 06-20-2016, 08:31 AM
  5. Why can't I login to my Samsung account?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 06-20-2016, 08:28 AM
