1. Brock297's Avatar
    I'm at work and I look down and see a screen that says "Encryption unsuccessful" along with a couple of paragraphs basically saying the phone can't access the data (if anyone needs the complete verbiage, let me know). I didn't try to encrypt phone so no idea where this came from. Stock phone, no hacks or anything. The only option is to reset to factory. When I select that, I get a screen with a number of options. They are:
    1. reboot system now (takes me back to encryption unsuccessful screen)
    2. apply update from ADB (Now send the package you want to apply...) - no idea what this is. Had to pull battery to reboot.
    3. wipe data/factory reset (takes me back to encryption unsuccessful screen)
    4. wipe cache partition (takes me back to encryption unsuccessful screen)
    5. apply update from external storage (I have no update to apply. more on this later)
    6. apply update from cache (unable to find an update)
    7. md5 check (does some stuff, reboot to encryption unsuccessful screen)
    One saving grace is that I was able to get a hold of another exact same phone. I do have an SD card, so is there some way to download an update to it and load it on the bricked phone (or any other way to fix it). Thanks
    Brock
    06-23-2016 01:21 PM
  2. Brock297's Avatar
    Also, It's a ZTE Sonata 4G LTE. Android version 4.1.2.
    06-24-2016 08:42 AM
  1. Andriod zte phone app, show duplicate phone numbers
    Last Post: 06-28-2016, 06:25 AM
  2. Replies: 1
    Last Post: 06-28-2016, 05:59 AM
  3. Encryption and Decryption
    Last Post: 06-23-2016, 09:25 AM
  4. How to move music to sd card on zte
    Last Post: 06-22-2016, 07:40 PM
  5. Question about encrypting my SD card
    By Qaddafi in forum Samsung Galaxy S7
    Last Post: 06-22-2016, 03:50 AM
