1. abdulahad12's Avatar
    Hey Guys.
    I have been trying to install TWRP using ODIN from past couple of hours. I cant seem to locate recovery file using ODIN that I downloaded from official website of TWRP. I tried to flash using ADB but cant figure out that as well. It seems to be very complicated. Kindly help me out.
    Thanks.
    06-24-2016 05:26 AM
  2. Ayybeeshafi's Avatar
    I have same problem. I have zip file of TWRP but my ODIN wont recognize it at PDA/AP..
    Did you find any solution yet?
    abdulahad12 likes this.
    06-26-2016 08:38 AM
  3. abdulahad12's Avatar
    Yes. I have found its solution.
    Get the Zip file and flash it via Flashify app.
    Or You can use ROM manager to install custom recovery on your phone.
    ROM manager for CWM and TWRP manager for TWRP.
    These apps require root.
    If you still have any confusion see this guide.
    06-26-2016 08:49 AM
  1. Missing Contact Photos since Marshmallow on my S5
    By lachambers in forum Samsung Galaxy S5
    Last Post: 07-02-2016, 12:59 AM
  2. Why am I unable to connect to my server?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-26-2016, 12:51 PM
  3. How do I turn off the notification vibration on my Lenovo mobile?
  4. Why is it using battery to charge
    Last Post: 06-24-2016, 05:44 AM
  5. Replies: 2
    Last Post: 06-24-2016, 04:50 AM
