1. AC Question's Avatar
    Email message says 'Getting your messages'. I've turned phone off and on, re-signed in to Hotmail and my WiFi, but still no luck. Any ideas?
    06-24-2016 09:19 AM
  2. mhinc's Avatar
    Are you using the Outlook App? If so it's garbage! Use Gmail, you can set up your hotmail within the gmail app without issue, it's much more reliable, and user friendly
    06-25-2016 04:49 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! If you're using the stock Email app, then try removing the Hotmail account from the Email app, and then add it back again.
    Also, do you have 2-step authentication turned on for your Hotmail/Microsoft account? If so, you may have to turn it off temporarily.
    06-26-2016 03:20 AM
  1. Replies: 1
    Last Post: 06-26-2016, 01:40 PM
  2. my s6 keeps restarting and it cant go on
    Last Post: 06-24-2016, 04:33 PM
  3. Anyone comment on dropped calls?
    By ptm88 in forum OnePlus 3 & 3T
    Last Post: 06-24-2016, 02:35 PM
  4. How do I disable the Verizon drive mode on my Galaxy S5?
    By Kalel56 in forum Samsung Galaxy S5
    Last Post: 06-24-2016, 08:35 AM
  5. How do I decrypt my files on my HTC One?
    By AC Question in forum HTC One Series
    Last Post: 06-24-2016, 08:18 AM
