1. Helpmewithmytablet's Avatar
    Ok my tablet is at 93%and when it shut it down and turn it back it's still at 93% and idk how to fix it it's not draining it's battery it's still a 93% plz help
    06-27-2016 02:09 AM
  2. sinfoman's Avatar
    Help me, help you! What tablet and what OS are you running?
    06-27-2016 01:47 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Merged a couple of duplicate threads here.
    Try recalibrating the battery sensor software by using the device normally until it shuts off automatically from low battery. Then charge up fully, and then repeat this 2 or 3 times. Does that help?
    06-27-2016 11:25 PM
  1. need some help with Lg support
    By dmoz47 in forum LG V10
    Last Post: 10-15-2016, 10:19 AM
  2. hey guys i need help please
    By paperclik0316 in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 06-27-2016, 11:35 PM
  3. Help with good lock
    By Rmbrown1964 in forum Samsung Galaxy Note 5
    Last Post: 06-27-2016, 03:25 PM
  4. How can I block someone from calling and texting me
    Last Post: 06-26-2016, 10:40 PM
  5. Micro SD help! Cant format/write (not write protected)
    Last Post: 06-26-2016, 09:57 PM
