1. Champion RunNGun's Avatar
    Hi everyone. At first my phone memory was 4 GB. I am using it now for like 2 months and my phone memory is low at the memont with only 500MB available. My phone maximum storage is 32 GB. I think of getting a 16 GB SD Card. Do I need to backup anything? I don't want to lose any files, like music, apps data, photos, etc...Can I just simply Insert the 16 GB SD card and that's good and I won't lose anything? Help please
    06-28-2016 03:43 AM
  2. anon(123856)'s Avatar
    You shouldn't lose anything by inserting an sd card. You'll probably only be able to move pictures and music over to it though. That alone could save some significant space in the internal memory of your phone though. I would get at least a 32 GB card if you can swing it. Not much more expensive and you'll have loads of room.
    06-28-2016 07:30 AM
  3. Champion RunNGun's Avatar
    Thanks for the answer man. You're right that 32 GB is good but i am afraid that the phone might stuck and get slow...You mean that I need to move the music and photos to the new card ? Or they will be already in the phone when i insert the new card? Thanks again...
    06-28-2016 08:43 AM
  4. anon(123856)'s Avatar
    I was assuming that some of your storage was being consumed by music and photos. If that is true the OS *may* offer to move them for you. If it doesn't then you can move them over to the card. Get a fast card (Class 10) if possible. The speed difference will be noticeable.
    I use my sd storage for pictures, music, videos and some backups.
    06-28-2016 10:19 AM
  5. Champion RunNGun's Avatar
    I finally just inserted the card and it worked fine. Nothing was lost, everything was in their place. Thanks for the answer thought.
    anon(123856) likes this.
    06-29-2016 06:37 AM
  6. anon(123856)'s Avatar
    Good to hear.
    06-29-2016 07:12 AM
  1. How can I access the Google play store?
    By AC Question in forum Google Play Store
    Last Post: 10-21-2016, 08:53 PM
  2. Replies: 1
    Last Post: 07-08-2016, 04:48 PM
  3. Bell TV app wants me to disable "allow mock locations "
    By csubi in forum Samsung Galaxy Note 5
    Last Post: 06-28-2016, 01:47 PM
  4. How do I password protect individual S Notes on my Galaxy Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 06-28-2016, 02:44 AM
