1. AC Question's Avatar
    The camera on my Tecno F7 is only showing the front camera and can not change it to the rear camera as the icon for changing has disappeared
    06-28-2016 07:43 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this persist after a reboot? If so, then try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    06-28-2016 10:57 PM
  1. Why won't my rington change?
    By JH33 in forum Samsung Galaxy S6
    Last Post: 07-05-2016, 12:24 PM
  2. Why won't my Motorola Droid Turbo charge with the charger?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 07-03-2016, 03:09 PM
  3. Replies: 10
    Last Post: 06-30-2016, 01:31 PM
  4. Replies: 1
    Last Post: 06-28-2016, 11:01 PM
  5. Why am I getting messages based on time and not on date?
    Last Post: 06-28-2016, 07:05 AM
