1. AC Question's Avatar
    Browsing suggestions from Google start with "Mobael-ndey∆e". The ∆ represents a character that I can not find to type. The rest of the suggestion is in English. What causes this? How can I fix it?.
    Thank you!
    06-28-2016 09:46 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using the Google Search app or the browser? Does this happen in both places?
    06-28-2016 10:20 PM
  1. Replies: 3
    Last Post: 04-18-2017, 12:16 AM
  2. why doesn't snapchat filter work on my galaxy s5 phone
    Last Post: 08-31-2016, 04:00 AM
  3. Problems with battery drain after Marshmallow and cache deletion.
    By albion01 in forum Samsung Galaxy Note 4
    Last Post: 06-29-2016, 01:34 PM
  4. How much time does it take to download the new Marshmallow OS?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 06-28-2016, 08:58 AM
  5. Replies: 1
