1. BFishles's Avatar
    Hello. So I have a Moto X 2nd Gen (AT&T) that I use to use for a very short time. About 2-3 months after I got that I received a Nexus 6 (AT&T). I have been using the Nexus 6 for a while now, and I want to switch back to the Moto X because I have been having issues with the Nexus.
    So I boot up the Moto X, and it has already been wiped, so I go through the setup and login to my main Google account, but the only backup it shows is the one from the Moto X before I stopped using it. If instead I opt to do the phones back to back NFC transfer during the setup process, it always says completed but never transfers anything.
    If I skip it all and set it up as a new device, I go to open the Play store and it crashes every time within seconds. I then tried logging in with one of my secondary Google accounts and then it allows me to use the Play store just fine.
    I just want to load up my backup from my Nexus onto the Moto X. I have checked my dashboard and verified there is a backup for it. What are your thoughts folks?
    Thanks for any help!
    07-03-2016 11:22 AM
  2. kramer5150's Avatar
    Does it matter what Android version the two devices are running? I didn't think you could take a MM backup and restore it onto a KK or LP for example. (if that is indeed what you are trying to do)
    07-03-2016 12:27 PM
  1. Replies: 7
    Last Post: 08-30-2016, 08:35 PM
  2. I forgot my password for my s5 sport but i know my backup
    Last Post: 07-05-2016, 03:33 AM
  3. Replies: 1
    Last Post: 07-05-2016, 02:41 AM
  4. With headphones plugged in sound still comes out speaker
    By 25544 Norad in forum Samsung Galaxy Core Prime
    Last Post: 07-04-2016, 12:57 PM
  5. Replies: 0
    Last Post: 07-03-2016, 10:15 AM
