1. GOODRO's Avatar
    I have a question for you...
    Can I do this with my Tablet?
    Example: when in my truck I want to "see and control" my calls and text messages from my Samsung Note 4 smartphone via/to my Samsung Tab S tablet that has data plan (it's own phone number)
    Note: I use my tablet for work as a docked navigation tool mostly that I run CarHome Ultra app from the google play store.
    My goal is not to have to look down at my phone to see who is calling or texting me
    and to dial outgoing phone calls and answer them as well.
    in the end, I'd like to use my tablet that is docked via magnet holder on my dashboard of my truck to control my phone and text messages.
    07-03-2016 02:58 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Just to clarify--the phone has its own voice/data service, but you want to control it using the tablet (which has its own separate data service), correct? You could try ScreenShare, although I've never tried it myself.
    EDIT: Actually, sorry--it looks like that app doesn't handle calls ...
    Maybe try SideSync instead.
    07-03-2016 04:48 PM
  1. Why are my incoming calls going directly into my voicemail
    Last Post: 07-05-2016, 02:59 AM
  2. Replies: 1
    Last Post: 07-03-2016, 03:32 PM
  3. Can't use "USB storage" on phone.
    Last Post: 07-03-2016, 02:30 PM
  4. If your SMemo files were authorized to sync yesterday...
    Last Post: 07-03-2016, 01:50 PM
