1. fireillusion's Avatar
    Let's say that in Google chrome you are visiting a web page that has a drop down menu and the title is selectable. When pressing on the title to open the drop down menu it takes you to another web page. So you cannot see the drop down menu's contents.
    07-07-2016 01:49 AM
  2. Mooncatt's Avatar
    Try pressing and holding the title button until the options window pops up (open in new tab, copy link, etc options). Then close that window and the drop down menu should be expanded.
    fireillusion likes this.
    07-08-2016 09:39 PM
  3. fireillusion's Avatar
    Thank you. Your solution works fine
    Mooncatt likes this.
    07-14-2016 04:50 PM
  1. Replies: 1
    Last Post: 07-08-2016, 06:42 PM
  2. Replies: 1
    Last Post: 07-08-2016, 06:32 PM
  3. Replies: 1
    Last Post: 07-08-2016, 06:27 PM
  4. Can someone identify this message?
    Last Post: 07-07-2016, 02:04 AM
  5. Unfortunately, the process com.android.phone has stopped?
    Last Post: 07-07-2016, 01:49 AM
