This started a few days ago on my Samsung Galaxy S4 running 4.4.4 on T-Mo.
They show up at the bottom of the screen, and in the same place every time. It seems random. I was finally able to get a screen capture of the 2nd part.
Here's a link to the screen cap in my Dropbox:
https://dl.dropboxusercontent.com/u/3312790/Screenshot_2016-07-11-14-20-56_EDIT.png
The first part that shows up is just Asian (Japanese or Chinese?) symbols. Then the part that I was able screen capture shows up. Each of these two things that flash on the screen are only there for 2-3 seconds each.
I have not installed anything that's not on Play Store and nothing new within the last few days. The Install unknown apps is turned off.
Anyone know what this might be?
07-11-2016 01:54 PM
