1. Funkpod's Avatar
    okay,
    i dont' exactly know how this problem started, but i think it was because i pulled my phone out of the usb on my computer before i had ejected it.
    i can see files both on my computer and in astro, however, it does NOT show up in gallery.
    i had just reformatted my sd card and put everything back on there... it's weird, i can't see certain file folders.
    does anyone know what to suggest me to do?
    i might end up hard resetting...
    03-20-2011 03:00 PM
  2. takeshi's Avatar
    Make sure you're actually looking at the SD card contents and not any internal storage. You don't mention your device so it's impossible to tell if this is applicable to you or not.
    03-21-2011 08:51 AM
  3. Funkpod's Avatar
    sorry, i have a droid incredible.
    and i am looking under "sd card" and it does not reflect what is on my card...
    i need to try and repair some damage to the files that i have lost, maybe that'll give me a clearer picture of what i have
    03-21-2011 09:20 AM
  4. ak2j's Avatar
    I have a tb. How do you access your SD card from you phone
    03-21-2011 05:42 PM
