1. Grejx's Avatar
    Please please please can anybody help??. Ive read so many forums saying you just need to go to settings, app manager, google launcher, wipe cache and data, then reset. Nothing changes for me and im at the point of deleting launcher (but i love it sooo much).
    I get the error message every 5 seconds or so....im in an S5.
    Thanks
    07-14-2016 07:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using the stock TouchWiz Home launcher, or did you install Google Now Launcher?
    07-15-2016 02:13 AM
  3. sandra baros's Avatar
    I recieved My tablet as a retirement gift and the Launcher 3 was already set up, and now it says Launcer 3 has stopped.
    07-21-2016 07:48 PM
  4. Golfdriver97's Avatar
    Welcome to the forums. You can install another launcher to your device by going into Google Play on a desktop computer, sign in with the same GMail, and install them that way. Nova is a good launcher.
    07-21-2016 08:21 PM
  5. B. Diddy's Avatar
    Which tablet do you have? Does this persist after a reboot?
    07-23-2016 07:45 PM
  1. Has there been an update in the last two days that chews battery?
    By Doc Marten in forum Samsung Galaxy S7 edge
    Last Post: 07-19-2016, 08:47 PM
  2. can i tell if my deleted text has been overwritten on samsung
    Last Post: 07-19-2016, 01:03 AM
  3. Replies: 6
    Last Post: 07-14-2016, 08:21 PM
  4. My 5X has extra text in the back
    By Gazella in forum Nexus 5X
    Last Post: 07-14-2016, 09:55 AM
