1. AC Question's Avatar
    Hi I have a 4 months old YU YUNIQUE handset. I had a screen protector on it(the transparent plastic one)
    Today my phone failed down on exactly its bottom right corner edge. Now its outermost glass (gorilla glass Corning 3) is cracked in hundred pieces. I just peeled off the screen protector (plastic).
    Handset's display and touch working perfectly (no pixel black, no lining or blurred colors etc).
    Now with all these informations, can anybody help me out with what could be done in this case.... do I need to replace just glass or glass with Digitizer or lcd+touch digitizer+glass?
    07-14-2016 11:16 PM
  2. Rukbat's Avatar
    YOU need to bring the phone to a repair shop. THEY need to replace the glass. (Doing it yourself, unless you've done it a few times already, is going to end up costing you a new screen.)
    07-15-2016 05:37 AM
  1. Will the screen break if I use this car mount?
    By acsurfer in forum Samsung Galaxy S7 edge
    Last Post: 07-15-2016, 02:36 PM
  2. What is best sd card for my lgl34c phone
    Last Post: 07-15-2016, 07:04 AM
  3. Impressive battery life - 44hrs, 8 hours screen time.
    By Slade8525 in forum Samsung Galaxy S7 Active
    Last Post: 07-14-2016, 10:42 PM
  4. Replies: 0
    Last Post: 07-14-2016, 10:12 PM
  5. What small tablet is best for AT&T Data Plan?
    Last Post: 07-14-2016, 10:07 PM
