A AC Question Jul 15, 2016 #1 Phone remain locked asking for passcode, forgot. Show me how to unlock from asking my password instead of my fingerprint.
A anon(632115) Well-known member Jan 5, 2012 4,315 0 0 Visit site Jul 15, 2016 #2 Re: Phone remain locked asking for passcode, forgot. If the phone has been switched off or not used for over 24 hours you will be asked for a password. There is no workaround AFAIK
H3aTeRzz Well-known member Oct 8, 2013 2,810 0 0 Visit site Jul 15, 2016 #3 Re: Phone remain locked asking for passcode, forgot. Hi there If you didn't set up Find My Mobile or Google Device Manager, to which would allow you to change the passcode, then there is no way to bypass the "forgotten password!" Chris
