I have stumbled across a tip for the Captivate user. And I thought it may help someone. I could never get a personal ring tone or notification on the default samsung ring tone menu.
I blue tooth my tones from my laptop but however you get yours is fine. So i bt (blue tooth) my file over. Open the bt folder. Hit the home button on the phone, select the "more" tab select the tone,then either move or copy. then arrow back and go to the media folder, audio, then select either ringtones or notifications and paste it in the folder. close it out. then go to your settings,sounds and the ringtone. and then you can select the tone you just copied over. Hope it helps your out.
