1. AC Question's Avatar
    I have the update start in the middle of the night so as not to interrupt anything. When it comes on it lights up the house like Yankee Stadium. How do I get it to do the update in the dark?
    07-20-2016 07:51 AM
  2. Javier P's Avatar
    Welcome to the forums. It's not a good idea messing with the phone while a system update is being installed, you could end with some serious problem. You just need to be patient, sorry
    And don't cover it with a cloth or something, a system update will generate an extra heat. It could be dangerous.
    07-20-2016 07:56 AM
  3. chanchan05's Avatar
    Put it in a box. Close the lid. Make sure it's not too warm.
    07-20-2016 08:31 AM
  1. Replies: 5
    Last Post: 07-23-2016, 03:57 AM
  2. Is there a way to block unknown, private calls?
    By OptimusTarzan in forum HTC 10
    Last Post: 07-20-2016, 03:43 PM
  3. My org.mail.power.update, any ideas?
    Last Post: 07-20-2016, 09:08 AM
  4. Replies: 2
    Last Post: 07-20-2016, 09:06 AM
  5. Does anyone know how to deactivate VMware AirWatch?
    By AC Question in forum AirWatch
    Last Post: 07-20-2016, 08:10 AM
