Hi, I installed google now and Nova launcher. After trying both of them, I think I clicked 'set nova laucher as default', now...
1) will the google now launcher work in the background draining battery? (and touchwiz?)
2) Extra question, do you know how to get rid of the samsung lock screen and get the stock android one? (coming from a nexus 4)
3) This j5 is temporal, i'm doubting between waiting for the nexus 2016 (october/november) or getting the s7 edge now and not even look at the phones that are coming because i plan to stay with it at least 3 years? What would you do?
07-20-2016 11:30 AM
