My 3.5 year old tablet just isn't what it used to be. It is now a little slow. Why does this happen? And will a factory reset fix this?
A factory reset will have it running like a champ!
They don't slow down overtime but there are several reasons as to why the UI might be sluggish
-Too many apps running in the background
-Cache partition is too big or you are low on space
-NOT ENUFF RAMMM
-No trim (which is rare)
Maybe try and install Greenify and reboot it every once in a while!
