1. kelvin carlisle1997's Avatar
    I have a LG G4 and a couple of weeks ago I drop it and it cracked a little. I Was plying a app on my phone when suddenly the screen went black and I cant turn it back on. Is there anyway to fix this problem?
    07-20-2016 08:24 PM
  2. Silver Soul's Avatar
    What do you mean "black"
    Did you check if the phone charges???
    Is the power button broken???
    If the LG logo is coming up and the phone is in a state where it's stuck rebooting then your phones a Brick now unless you replace your motherboard, you can thank LG and their infamous boot loop fiasco!
    Maybe something broke?? (tho it should have stopped turning on when you first dropped it which confuses tf out of me )
    Well to answer your question you will have to tell us more about it! Pictures will help :3
    07-20-2016 08:44 PM
  1. How can I disable fingerprint on Galaxy S7?
    Last Post: 07-25-2016, 07:13 AM
  2. Rooting my Note 5?
    By Samuel Moren in forum General Help and How To
    Last Post: 07-21-2016, 01:19 AM
  3. Samsung s7 edge screen
    By Lance Vandyke2 in forum Samsung Galaxy S7 edge
    Last Post: 07-20-2016, 11:45 PM
  4. Transfer upgrade from dumb phone to smartphone
    By VooDooCC in forum Verizon
    Last Post: 07-20-2016, 08:21 PM
  5. How do I turn on call waiting on my Galaxy S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 07-20-2016, 07:30 PM
