Is this something that depends on the specs of phones and computers in general or since I'm using a HEADSET, should the maximum volume normally be the same on any device? Hardware-wise, my headset should be capable of higher volume since when I use it on my PC it certainly can be louder (almost twice louder) than when I use it on my phone (Lenovo A5000).
If it is the case that the headset volume will differ on different devices, why is this so? Is this a software limitation on a particular device or is there also something hardware that affects the output on the headset? If it's a software limitation, are there any apps that I can use to actually maximize the volume my headset is actually capable of?
Cheers!
07-21-2016 06:18 AM
