1. 678GUY's Avatar
    i am trying to install xposede framework on galaxy s6 6.0.1 SM-G920F0 and they say that you need to have a Stock (Odexed and Deodexed) 5.1/6.0 Roms what does it mean ?
    is it a rom that is odexed and deodexed at the same time or that i need to have odexed or deodxed plz help i realy need xposed framework
    07-24-2016 10:01 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    From what I understand is Odex is when APKs are split apart and optimized to speed up booting time. DeOdexed is when APKs are reassembled to allow for easier customization.
    I just don't get why you need both. You can only run one ROM at a time, and as far as I understand a ROM can only be one or the other, not both. Can you link to where you saw this?
    07-24-2016 10:19 AM
  3. 678GUY's Avatar
    this is what it says here ill give you the post
    [UNOFFICIAL][5.1/6][v86.0][09 Jul]Xposed for Samsung Lollipop/Marshmallow
    it says
    Prerequisite:
    - Stock (Odexed and Deodexed) 5.1/6.0 Roms
    - CWM recovery
    07-24-2016 11:29 AM
  4. rafgiav's Avatar
    Deodexed is a version of the stock OS that doesn't have some apps(mainly bloatware) that are installed by default. Propably you have an odexed rom if you don't know what that means.
    07-24-2016 02:30 PM
  1. Replies: 3
    Last Post: 09-10-2017, 02:43 PM
  2. Help! Accidentally wiped my system and data, removing OS.
    By Andres Guevara in forum Samsung Galaxy Tab S 10.5
    Last Post: 07-25-2016, 07:03 AM
  3. Replies: 2
    Last Post: 07-24-2016, 10:51 AM
  4. my phone is Samsung galaxy J2
    Last Post: 07-24-2016, 10:02 AM
  5. Why is my root directory so small
    Last Post: 07-24-2016, 09:03 AM
