1. Frank Am's Avatar
    I have a Samsung Galaxy Note 2 and I used to record my screen. but now, anytime I record a screen it doesn't save... I've tried 3 screen recording apps and the same problem.. One says "Unable to open '/storage/emulated/0/movies/res/filename.mp4':no such file or directory
    What should I do?
    07-29-2016 02:38 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What version of Android is the phone running? Are all of these screen recording apps installed from Google Play Store? Based on that error message you mentioned, I'm assuming these apps are trying to save to Internal Storage--but just to be sure, can you check to see if they're trying to save to an SD card?
    07-30-2016 08:47 PM
  1. Replies: 1
    Last Post: 07-29-2016, 02:44 PM
  2. The Google app on my LG G3 cell phone talks for no reason
    Last Post: 07-29-2016, 02:32 PM
  3. Replies: 1
    Last Post: 07-29-2016, 02:31 PM
  4. Replies: 0
    Last Post: 07-29-2016, 02:22 PM
  5. Any alarm app that will play music to my Chromecast?
    By Devin Stein in forum General Help and How To
    Last Post: 07-29-2016, 02:16 PM
